_L_J_
First solution authored 25 sign-ins First like received
  1. Can anyone let me know how to configure internal watchdog for tc397.
  2. I have configured this way it is showing internal trap while debugging
Aiswarya_A
250 sign-ins 50 solutions authored 10 likes received
We see that you are having a similar discussion in this thread.
Kindly continue the discussion there.
Kind Regards,
Aiswarya.
Aiswarya_A
Could you please let us know the trap class and trap ID of the trap that you are getting?
Kind Regards,
Aiswarya.
_L_J_
That issue got solved but when I update this (wdgConfig.enableAutomaticPasswordChange = 1;) microcontroller is getting reset
Aiswarya_A
It could be because you are not fetching the newly calculated password after enabling this feature. After setting wdgConfig.enableAutomaticPasswordChange to TRUE , the password changes automatically after each password check and follows a pseudorandom sequence based upon a 14-bit Fibonacci LFSR with characteristic polynomial x14+x13+x12+x2+1. So each time you have to calculate the new password based on this sequence.
Kind Regards,
Aiswarya.
Thanks for your Reply
I have implemented this Fibonacci LFSR , service is happening. later after 10 service microcontroller is resetting. Is this due to the password sequence repetition. the Fibonacci password sequence which i have implemented generates only five password sequences. later the same sequence repeats and  after that microcontroller gets a reset.
Aiswarya_A
Kind Regards,
Aiswarya.
