AURIX™ Forum Discussions
I have to use global C++ objects in my project. When I declare global objects, an object is created but the constructors are not being called.
I did some research and found that constructors have to be placed in .ctors section and the constructors will be called in the startup code by function _init linked using crti.o
but this is not working for me. Could anyone help in this regard
Thanks!!
Thank you HRusch!
But the link was for Destructor problem and still my problem is open!! and what will happen by the below statement
void *__dso_handle; I read in the link somewhere that adding this statement will solve the destructor problem!!
My latest tests showed me, that it worked.
You don't need -fno-use-cxa-atexit or void *__dso_handle anymore, if you are using the newest DAVE version.
I see that you use "Hightec compiler", therefore I cannot help.
C++ must be handled correct in the startup code of the toolchain.
