Hi
am using Tc37x
Alm6[19-21] is meant for the modules below
I have cleared the corresponding MTU alarms, but the SMU alarm 6[20] is not getting cleared
Any suggestion
Aurix
I have enabled mtu clock. I am able to clear other ECC errors[CPUx, DAM0] and corresponding SMU alarms
Just
DMA - Uncorrectable Critical error
PSI5 - Uncorrectable Critical error
SCR.XRAM - Uncorrectable critical error
SCR.RAMINT - Uncorrectable Critical error
GIGETHERNET.RX0 - Uncorrectable Critical error
GIGETHERNET.TX0 - Uncorrectable Critical error
These are creating a problem
If you see the image, all mtu alarms are disabled
ALM6[20] is the OR of following modules (I expect you have an TC39x):
MCDS - Uncorrectable Critical error
SDMMC - Uncorrectable Critical error
Alarm is not cleared because any of this modules has an uncorrectable critical error (e.g. SRAM not initialized).
Hi @MoD
am using tc37x
I have cleared all UCERR and SERR and FaultSTS of all "ORed" modules
Still after clearing smu alarm it doesnt get set to low
Hi
Can anyone please help me with this!
Check CCUCON5 that the GETHDIV bitfield is not 0. If GETHDIV is 0, then this can be result that ALM6[20] can't be cleared.
Hi @MoD
Thanks for the info, I will check once
If suppose GETHDIV is 0, then what should be done?
should just update GETHDIV to some other allowed value than 0? [ie 1,2,3,4]
Update: - I checked the GETHDIV value, it is set to 2 meaning fsource0/2. So that doesnt seem to be the problem
Any of the following RAMs has an ECC error therefore, you can't reset the alarm. Your software access any of this RAMs?
Initialize the RAMs via the MTU (memory test controller) to remove ECC errors.
Just
were u able to resolve the error? what was the problem
