how to change my cell phone number?
公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
AgelYen
First question asked Welcome!
Hi, I would like to change my cell phone number in my private profile. however, i could not change it. could you guide me how to change it when i login in?
0 点赞
14 回复数
slotg
100 comments on blog 50 comments on blog 25 comments on blog
常用邮箱 与 手机号码 是改不了,这也是bug吗?
0 点赞
crystal_rao
5 solutions authored First solution authored 250 replies posted
The email and cell phone number can't be changed in user profile once it is successfully registered, because we need to verify the email or cell phone before they can be registered to make sure the information is real. It doesn't make sense to allow user to make the change
0 点赞
_simple_
Level 4
Level 4
First like received 100 replies posted 50 replies posted
邮箱改不了可以理解,手机号改不了有点不是很不合理
0 点赞
Quanqiu
First like received 100 comments on blog 50 comments on blog
如果换了手机号,怎么办呢?
0 点赞
crystal_rao
手机号和邮箱是同一个道理吧,都是用来用户验证真实性的,如果随意可以改,那之前的验证不就无效了么?如果要换手机号,可以再注册一个id,或者用原来的邮箱来维护id
0 点赞
User12775
You could not change it. It is designed to avoid abuse behavior.
0 点赞
海中水
750 replies posted 500 replies posted 250 replies posted
这个确实可考虑解决一下。
0 点赞
mine
25 replies posted 10 replies posted 5 replies posted
换了手机号可能只能用邮箱登录了
0 点赞
mine
登录的密码不要忘记就可以
0 点赞
118
Level 4
Level 4
原来如此
0 点赞
118
Level 4
Level 4
为什么要改?
0 点赞
柳_
这个问题管理员得重视,注重人性化体验
0 点赞
飞马
会中文不?
0 点赞
SIX_66
Level 6
Level 6
First comment on blog 500 replies posted 250 replies posted
学习学习
0 点赞
