AURIX™ Forum Discussions
Hi all,
is there a possibility to connect an external RAM to TC234?
cwunder
The TC234 does not have an external bus unit (EBU) to support parallel memory devices. You would have to emulate this in software using port pins. You could consider using a serial based RAM (like SPI)
