_L_J_
First solution authored 25 sign-ins First like received
I have enabled error monitoring in TLF35584, but service is not happening properly.
can anyone help me with this.
like how frequently the error pin should be toggled.
Jeremy_Z
250 sign-ins 100 likes received 750 replies posted
Hi @_L_J_ ,
Actually, TLF35584 supports the time protocol that a low pulse of ERR is longer than the detection time tDET,LF.
BR,
Jeremy
Jeremy_Z
Hi @LokeshJaikumar ,
Thank you for your interest in Infineon Semiconductor products and for the opportunity to serve you.
Please go to try the demo code, further, there's an application note (AP32342) illustrating how to service the watchdogs.
BR,
Jeremy
_L_J_
Hi @Jeremy_Z ,
Thank you for your reply, i went through the demo code and i have enabled all three services two watchdog and error pin monitoring.
watchdogs is working fine.
error pin monitoring is not working, the FSP pin should be toggled at frequency 10 - 45 khz for valid service , but fault state time should be >=250us which is invalid  and cannot be changed below the value.
can you suggest any idea
Jeremy_Z
Hi @_L_J_ ,
BR,
Jeremy
