Translation_Bot
Regarding the choice of development environment, how do I know if it supports the development of the MCU I use
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83/td-p/669670
Translation_Bot
When choosing a development environment, you need to make sure it supports the development of the MCU you are using. Here are some ways to check if the MCU and development environment are compatible:
  1. Confirm the MCU model: First, please confirm the model of the MCU you are using. Generally, the MCU model can be found on the chip or in the data sheet, or if you already have a development board, check the model number of the development board to determine which MCU to use.
  2. Check the development environment's support list: Generally speaking, the development environment's official website or documentation will list the supported MCU list. You can check the support list to determine if the MCU you're using is on the list.
  3. Check the development environment's toolchain: Generally, development environments use specific compiler and debugger toolchains to compile and debug code. You'll need to check if these toolchains support your MCU. For example, if you're using an ARM Cortex-M series MCU, then you'll need to use a compiler and debugger toolchain that supports ARM Cortex-M.
  4. Check the development environment documentation: If you're not sure if your development environment supports your MCU, you can check the development environment's official documentation. Documentation usually provides instructions on how to configure a development environment to support a specific MCU.
Aurix supports a variety of compilers, including but not limited to the following:
  1. GCC Compilers: The GNU Compiler Collection (GCC) is a widely used collection of open source compilers, supporting multiple programming languages and multiple platforms, including AURIX. The GCC compiler is AURIX Development Studio's default compiler.
  2. TASKING Compiler: TASKING is a brand owned by Altium and provides software development tools for various embedded systems, including compilers, debuggers, emulators, etc. The TASKING compiler also supports AURIX.
  3. HighTec Compiler: The HighTec Compiler is a compiler designed for embedded systems and supports a wide range of microprocessors and microcontrollers, including AURIX.
  4. Green Hills Compiler: Green Hills Software is a company that provides software development tools and services for embedded systems, and its compilers also support AURIX.
Note that the features and performance supported by different compilers may vary, and you need to choose the one that works best for you according to your specific needs. Also, you need to ensure that your development environment and compiler version are compatible with your AURIX device.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83/m-p/669706
Translation_Bot
