公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
启航
5 questions asked First question asked First reply posted
我用的dap miniwiggler仿真器,为什么出现这个?没检测到芯片?就是keil里的硬件仿真,debug-->use infineon das client for xc16x-->settings->das server选择udas。但是device 和das interface 下面都显示no device connected。这是什么原因?
0 点赞
7 回复数
LED2013
First like received 1000 replies posted 750 replies posted
有没有检查过硬件连接的地方
0 点赞
雨停了
10 replies posted 5 replies posted 5 questions asked
想请问一下,主芯片用的啥
0 点赞
启航
谢谢你们,已解决,是jtag接反了
0 点赞
ZERO_GO
Level 6
Level 6
5 sign-ins Welcome!
板子上应该有丝印1,然后jtag左上角应该是第一个PIN,对应一下。
0 点赞
阳东
10 comments on blog 5 comments on blog First comment on blog
重新安全一下驱动试试
0 点赞
liliWinner
Level 6
Level 6
500 replies posted 250 replies posted 100 replies posted
检测硬件连接看看
0 点赞
User22064
10 sign-ins First like given 5 sign-ins
关注一下
0 点赞
