I get a KIT_A2G_TC387_5V_TFT and use the "AURIX_code_examples-master\code_examples\SPI_TLF_1_KIT_TC397_TFT" demo code want to debug the SPI, but after bulid shows "ctc E498: Vector table numbers are not allowed for TriCore "tc1.3"", what should I do fot this?
Thank you!
Hi CQ,
You have two options to solve it:
- Switch to the latest ADS release (ADS 1.9.0), import the project and rebuild.
ADS 1.9.0 is not affected by this issue.
- If you want to keep using ADS 1.8.0, you can add the missing option by:
- Right click on the “Libraries” folder
- Select “Properties -> C/C++ Build -> Settings -> TASKING C/C++ Compiler” and add the option as shown in the screenshot below
Please download ADS to build. https://www.infineon.com/cms/en/product/promopages/aurix-development-studio/
Below is a screenshot for your reference.
I meet the same problem When debugging TC397'project .How did you solve is?
The Erros as follow:
ctc E478: intrinsic __cmpswapw is only defined for the TriCore1.6.*
I know I need to change the configuration of TriCore. But I can't find where to modify in AURIX Studio.
Looking forward to your reply.Thank you!
CQ, please attached the project you failed to build.
Hi CQ,
