AURIX™ Forum Discussions
User21167
I am trying to work on EVADC program on TC332.
I have loaded baseSw of TC332 and source file of EVADC from iLLDs.
While compiling i am getting this error.
ctc E207: ["..\Src\BaseSw\Infra\Ssw\TC33A\Tricore\Ifx_Ssw_Tc0.c" 118/29] syntax error - token "" deleted
I have included desired path as well.
kindly suggest the solution.
Thank you
TBencher
First like given 50 sign-ins 10 solutions authored
Hi y,
yes this could be somehow related to the structure of your application.
Those weird compiler messages doesn't mean that the IFX library is broken.
If you like, you could drop me the project to info@tbench-solutions.com .
We could have a quick look on it.
I assume you are using Aurix Development Studio.?
Jens
