I have an AURIX starter kit TC277 V1.0 board, and I'm facing an issue running the Blinky_LED_1_KIT_TC277_TFT AURIX project.
When I run the debug, I get this error message :
Starting Debugger...
The debug instrument IO could not be initialized.
The GDI debug instrument provided the following error message.
An internal error has occurred.
When using the DAS Device Scanner I get a NO DEVICE
Am I missing something in the Blinky_LED_1_KIT_TC277_TFT project?
Furthermore, when following this documentation :
I see that the 4th step says : Three Power LEDs should be on. However after I connect the board to the pc and to the power supply, the LEDs are off, is that something normal?
Thank you in advance for your help.
Aurix
Hi Yassir,
Thanks for enquiry.
Could you please check your Power and Osc pins with multimeter and oscilloscope first? You can find related info from below link:
If you have no myicp account, please register one and apply for the access.
Hi Yassir,
Thanks for enquiry.
