May 25, 2021
03:19 AM
May 25, 2021
03:19 AM
Hello all!
I was browsing the internet looking for cool projects with AURIX, and suddenly I found this blog! https://aurixocd.blogspot.com/
It's a blog where this guy post updates on his open project, a debugger on command line for aurix! I tested the latest version (named AURIX_DEBUG_6) and it works pretty good! It does not need an elf file to debug but connects to the device and the guy implemented his own de-assembler. WOW
Furthermore, the guy discovered a flash tool inside ADS and by reverse engineering found some very interesting features. It looks like ADS comes with a stand-alone flash tool from command line as well! This is the link if you want to check: https://aurixocd.blogspot.com/2021/04/lets-flash-our-code.html
Did you guys know about this? never seen this guy on the forum as well, is it one of you??
01:26 PM
May 25, 2021
01:26 PM
Neat. Nobody I know.
