AURIX™ Forum Discussions
User17612
First like received
Hi all,
Can we successful write data into Pflash even if this address was already written with data 0x00 ? What will be happen ?
Lucas.
#8042000 13513
User18237
Hi Lucas,
Yes, you can successful write data into Pflash even if this address already written with data 0x00, but it will generate an ECC error because the new ECC value can't be programmed properly. This will cause a correctable or uncorrectable ecc error on the page of the address.
Always erase the sector before you write any value to avoid wrong ECC values and errors.
Mr. AURIX™
