Mar 03, 2020
02:52 AM
Mar 03, 2020
02:52 AM
Hi all,
Why many Pflash ECC errors are reported on high temperature test while room temperature/low temperature tests are ok?
Lucas
#8042000 13143
Lucas
#8042000 13143
06:08 AM
Mar 03, 2020
06:08 AM
Hi Lucas,
Check flash waitstate if it is enough to cover the access delay by PMU_FCON.WSPFLASH. The default setting is calculated with lower fFSI. with higher fFSI, you need to configure more waitstates.
Mr. AURIX™
Mr. AURIX™
Mar 10, 2020
09:52 AM
Mar 10, 2020
09:52 AM
Hello Support,
What is the corresponding register for Aurix 2G devices?
Looks like PMU_FCON.WSPFLASH is for Aurix 1G devices.
Best Regards
Best Regards
Mar 10, 2020
10:05 AM
Mar 10, 2020
10:05 AM
For TC3xx, check DMU_HF_PWAIT and DMU_HF_DWAIT.
