User17612
First like received
Hi all,
Why many Pflash ECC errors are reported on high temperature test while room temperature/low temperature tests are ok?
Lucas
#8042000 13143
User18237
Level 5
Level 5
First solution authored First like received
Hi Lucas,
Check flash waitstate if it is enough to cover the access delay by PMU_FCON.WSPFLASH. The default setting is calculated with lower fFSI. with higher fFSI, you need to configure more waitstates.
Mr. AURIX™
User9635
50 replies posted 50 questions asked 25 replies posted
Hello Support,
What is the corresponding register for Aurix 2G devices?
Looks like PMU_FCON.WSPFLASH is for Aurix 1G devices.
Best Regards
NeMa_4793301
Level 6
Level 6
10 likes received 10 solutions authored 5 solutions authored
For TC3xx, check DMU_HF_PWAIT and DMU_HF_DWAIT.
