Nov 07, 2019
01:30 AM
Nov 07, 2019
01:30 AM
Hi all ,
Does anyone know Why VDD pins need to be connected externally ?
Thank you in advance
KR
Christine
#8042000 13175
KR
Christine
#8042000 13175
03:07 AM
Nov 07, 2019
03:07 AM
Hi Christine,
Embedded voltage regulator (EVR) uses a close loop system to regulate the core voltage domain.
The VDD output pin is separated from the VDD feedback sense. If both pins are disconnected, the VDD output voltage may rise to VDDP3/2 ~ 1,7V, causing an over voltage condition.
Kind regards
Mr.AURIX™
Kind regards
Mr.AURIX™
