Attached Flash Memory map specifies Two addresses for each Flash Memory Location.
Start address of Flash memory appears as 8 / A000 0000 Hex
I believe the two addresses are as follows:
0x8000 0000
0xA000 0000
Is One logical and One Physical address?
What is the significance of Two addresses?
Attached is the memory map.
2501.attach
cwunder
5 likes given 50 likes received 50 solutions authored
It allows for cached (segment 😎 and non-cached (segment A) accesses to memory.
