AURIX™ Forum Discussions
User39504831
5 questions asked 10 sign-ins 5 replies posted
Am using Tc37x, and using tricore tasking compiler for the compile and build process.
On the other hand I want to test my  source code in the form of unit tests [ am using google test and gcov to get the coverage of the unit tests]. Which compiler is preferred for this. Can normal GCC, GNU be used?
Nambi
Moderator 100 replies posted 10 likes received 25 solutions authored
There is no specific recommendation for this use case. Below are the compilers supported in general.
https://www.infineon.com/cms/en/tools/aurix-tools/Compilers/
Best Regards.
