May 19, 2020
11:32 AM
May 19, 2020
11:32 AM
Hello Support,
Shown below is a snippet from TRAPSTAT register Bit 2 .
Can you please tell me what is the source for this TRAP2?
What configuration does set this Bit TRAP2?
Please provide some section number from the User Manual where TRAP2 is described.
Best Regards
Best Regards
May 20, 2020
08:20 AM
May 20, 2020
08:20 AM
That is set from TRAPSET.TRAP2. Writing 1 to TRAPSET.TRAP2 sets TRAPSTAT.TRAP2 to 1.
May 20, 2020
03:02 PM
May 20, 2020
03:02 PM
Hello Support,
So when software triggers TRAPSET.TRAP2, then it is not a CPU Trap generation I suppose.
If not, then which SMU Alarm Signal will be activated?
If it is a CPU Core Trap, then what is Trap Vector Number and what is the expected value of D15 Register [TIN] upon entering CPU Trap Vector.
Best Regards
Best Regards
May 21, 2020
01:20 AM
May 21, 2020
01:20 AM
I believe that this causes an NMI trap (non-maskable interrupt), so TIN=0, class=7 (so CPU core trap).
Oct 28, 2021
12:25 AM
Oct 28, 2021
12:25 AM
Hi all
so this is only activable via SW. Or it might be related to some HW pins as ESR0/ESR1?
Oct 28, 2021
06:16 AM
Oct 28, 2021
06:16 AM
It is only activatable via SW.
