AURIX™ Forum Discussions
User9635
Level 4
Level 4
50 replies posted 50 questions asked 25 replies posted
Hello Support,
Can you please provide me the Version 3.0 EABI Spec from Infineon AURIX devices?
Thank you.
User13290
First solution authored
baexps_pr1 wrote:
Hello Support,
Thank you.
You will first need to register to MyInfineon. The first time you logon your dashboard will only have a limited set of permissions. This does not include access to AURIX documentation. For that you must send an e-mail to AURIX@infineon.com and ask them to bump your permissions. They will need to know your login name so they know who to assign it to. Once that it all set and done, you can re-logon and click on the "enter collaboration platform" button. This will redirect you to a 2nd dashboard which should be populated with a link that redirects you to your aurix documentation.
Henk-Piet Glas
Principal Technical Specialist
User17451
10 replies posted 5 replies posted 5 questions asked
Dear member,
Where is Version 3.0 EABI Spec at the web site ? I can only find Version 2.9 EABI spec.
