Dec 18, 2019
04:02 AM
Dec 18, 2019
04:02 AM
Hi all,
P-channel FET is used for LDO mode with external pass device for EVR13 in AURIX™-TC275.
Could you please let me know any guideline to select P-channel FET for LDO mode? In AURIX™-TC2x5 Triboard, Infineon SPD04P10PL is used
Furthermore, I can find only specification for P-N channel FET for SMPS mode in the datasheet.
#8042000 19738
Kind regards
Bernie
#8042000 19738
Kind regards
Bernie
05:35 AM
Dec 18, 2019
05:35 AM
Hi Bernie,
The EVR13 LDO design with external pass device is very sensitive to variation of parameters. It requires a lot of simulations to check if it works under all conditions.
Only the two options below are supported.
Option 1: SPD04P10PL MOSFET with output capacitor of 4.7uF.
Option 2: IPD50P04P4L-11 MOSFET with output capacitor of 10uF.
Kind regards
Mr AURIX™
Kind regards
Mr AURIX™
