Nov 07, 2019
01:52 AM
Nov 07, 2019
01:52 AM
Hi all ,
What is all pin status during standby mode on AURIX™-TC2xx?
Kind regards
Christine
#8042000 12464
Kind regards
Christine
#8042000 12464
Nov 07, 2019
03:10 AM
Nov 07, 2019
03:10 AM
Hi Christine,
TC29x/TC27x
GPIOs : PU or Tristate by PMSWCR0.TRISTREQ
ESR0 : Open drain with weak PU or Tristate by PMSWCR0.ESR0TRIST
ESR1 : PU
Pin A/B : PU or Tristate by PMSWCR0.TRISTREQ
PORST Output : Weak PD
TC26x
ESR1 : PU
TC23x/22x/21x
GPIOs : Tristate (except P14.1, P14.3, P14.6 and P21.7 which are with PU)
ESR1 : PU
Pin A/B : Tristate
I hope that was the answer you were looking for .
Kind regards
Mr.AURIX™
TC29x/TC27x
ESR1 : PU
TC26x
ESR1 : PU
TC23x/22x/21x
ESR1 : PU
Pin A/B : Tristate
Kind regards
Mr.AURIX™
Jan 11, 2020
07:06 PM
Jan 11, 2020
07:06 PM
Hello Support,
Can you please tell me which Pad or Port or BGA Ball you are referring for Pin A/B:?
My device is TC297 BGA-292 package.
You can tell me for any package, that is also fine.
I can map it correspondingly.
Thank you.
Thank you.
Jan 11, 2020
07:35 PM
Jan 11, 2020
07:35 PM
PINA is 14.1 (ball A15 on a TC297). It's labeled EVRWUPA in the datasheet, which isn't a very direct link.
PINB is 15.1 (ball A18 on a TC297). EVRWUPB in the datasheet.
Jan 12, 2020
07:29 AM
Jan 12, 2020
07:29 AM
Hello Support,
In my hardware design HWCFG[6] is strongly pulled to ground for TC297 device, HWCFG[6]=0.
So, according to TC29x user manual, the port pins are in Tri-State after Cold Power On Reset, till software changes the default pin behavior during run-time.
PMSWCR0.TRISTREQ is kept at default value of zero by software.
During any subsequent run-time Warm Reset/ System Reset / Application Reset of the hardware, will the port pins become Tri-State irrespective of run-time software configuration when PMSWCR0.TRISTREQ=0 is maintained by software?
Or, I must make PMSWCR0.TRISTREQ=1 to go to Tri-State during Warm Reset/ System Reset/ Application of the hardware?
Thank you.
Thank you.
Jan 14, 2020
07:04 AM
Jan 14, 2020
07:04 AM
The value of the PMSWSTAT.TRIST bit determines the behavior of the pads.
When you have HWCFG[6] = 0 latched on a Cold PORST this places the pads in tristate mode and any subsequent run-time Warm Reset/ System Reset / Application Reset of the hardware will maintain this pad behavior.
Changing PMSWCR0.TRISTREQ bit will update the PMSWSTAT.TRIST bit and respectively the pad behavior.
