AURIX™ Forum Discussions
User17740
First like received
Hi all,
could you please let me know what is a Standby Controller (SCR) on AURIX TC3xx ?
Thanks!
Bernie
#8042000 19492
User13290
First solution authored
Hi Bernie,
I recommend you take a look at AP32332 available within the MyICP portal. Standby mode is typically used to have AURIX enter (or wake from) a low power consumption mode. This application note will walk you through it.
Henk-Piet Glas
Principal Technical Specialist
Embedded Software
User18237
Hi Bernie,
SCR is an 8-bit microcontroller that can continue to run during the standby mode in order to reduce current consumption until the main core/cores wakes/wake up.
Mr. AURIX™
User20124
10 sign-ins First question asked First reply posted
HIGHTEC.henk-piet.glas wrote:
Hi Bernie,
Henk-Piet Glas
Embedded Software
Hello Henk-Piet,
is your mentioned application note still valid? I've searched for it but couldn't find it at MyICP.
Jens
User20124
Jens wrote:
Hello Henk-Piet,
Jens
Ok, I guess I found an app note for the SCR, but with a different number, "AP32465 Standby controller and standby mode of AURIX™":
https://myicp.infineon.com/sites/microcontrollers-aurix_customer_doc/Lists/defaultdoclib/AURIX%20TC3...
But thanks anyway for pointing the direction.
MoD
250 sign-ins 25 likes received 50 solutions authored
The AppNote is valid and available via myicp.
Look in the folder AURIXTC 2xx -> 00 AURIX TC2xx General -> 04 Application Notes
There you will find AURIX_Standby_Power_Mode__AP32332.pdf
To get information about SCR you must check the user manual, the AppNote describe only the power modes.
