Oct 23, 2019
07:13 AM
Oct 23, 2019
07:13 AM
In the documentation the signal ENPS (Enable Power Supply) is mentioned. What is this signal doing?
Thanks a lot and regards
Lucas
#8042000 12665
Lucas
#8042000 12665
05:26 AM
Oct 28, 2019
05:26 AM
This is a signal coming from the power management inside AURIX.
This signal is used to bypass the pad configuration and controls the pad states during power supply ramps.
If the signal is not active, the pad in tri-state mode.
Christine
Christine
