_L_J_
First solution authored 25 sign-ins First like received
I have enabled cpu watchdog and need to enable (wdgConfig.enableAutomaticPasswordChange = 1;) but when i enable this bit device is getting soft reset.
Can anyone let me know whats happening and any solution for this issue.
Nambi
5 likes given 100 solutions authored 250 replies posted
We see that you are having a similar discussion in this thread.
Kindly continue the discussion there.
Best Regards.
Jeremy_Z
250 sign-ins 100 likes received 750 replies posted
Hi @_L_J_ ,
Thank you for your interest in Infineon Semiconductor products and for the opportunity to serve you.
I was wondering if you show the codes that cause the above phenomenon.
BR,
Jeremy
_L_J_
Hi @ ,
Thank you for your reply. that issue was resolved. but my microcontroller gets reset after 10 services. I have implemented the Fibonacci series and it is generating 5 passwords that is repeated. after second repetition of same password sequence microcontroller gets reset.
 this is the code for my password generation
Nambi
Best Regards.
