AURIX™ Forum Discussions
User20310
First like received
I'm working with the EVAL TC397 Hardware and I'm having a problem related to the reset for watchdog. when I connect the device with the debugger and flash my code, it works . means Wdg driver getting called. Rest will not work because Debugger will hold reset pin.
But when i remove debugger the power off or pressing the reset button, Then Reset LED glow(means reset happening). and nothing will work.
1.How to work with debugger mode?How to enable wdg in debugger mode?how to active watchdog in debugger? so that i can debug issue
2.What could be the reason for reset?
Thanks and Regards
sachin
