sdkeng
First question asked Welcome!
We are exploring the use of AURIX controllers in an upcoming project.
But I am having a difficult time navigating the documents.
Wake up sources are not collected and mentioned in one single place.
I can see that CAN wake up is supported. So does that mean we can wake up from CAN packet during standby mode?
Also is ethernet wake up supported?
Is there some doc that explains all this clearly?
Prudhvi_E
250 replies posted 100 solutions authored 25 likes received
I hope you're using TC3xx device. In that case, please refer to the section "11.2.3 Power Management" and sub-sections 11.2.3.4 Standby Mode of the "11 Power Management System (PMS)" chapter for details regarding entering and exiting the stand-by mode in the User manual below:
https://www.infineon.com/dgdl/Infineon-AURIX_TC3xx_Part1-UserManual-v02_00-EN.pdf?fileId=5546d462712...
For CAN-based wakeup from Low Power mode, please see section "11.2.3.3 Sleep Mode" where it describes how to se the System to Sleep mode and wake based on a CAN ISR.
Prudhvi.
