05:25 AM
Jul 28, 2017
05:25 AM
Hello together,
I am facing a little problem with the Tc2X5 AppKit, i have Debug Connection to the Board and also the Device Manager shows the DAS JDS COM and the DAS JDS DEBUG Connection. (looks similar to the TC3X Board)
But there is no VirtualCOMPort created for the TC2X5 Board. With the TC3X Board there is a Virtual COM Port witch is also working.
Are there any common issues with the TC2X5 Boards or is there a need for an additional Driver.
Thanks for your help
05:57 AM
Jul 28, 2017
05:57 AM
This sometimes happens. What you need to do is to go to the advanced properties of the DAS JDS COM driver and then tick the "Load VCP" checkbox as seen here:
Then temporarily disconnect the board to force the driver being reloaded. There should now be a virtual com port. Special thanks to Neal for helping me with this in the past.
Henk-Piet Glas
Principal Technical Specialist
Rico wrote:
Hello together,
Henk-Piet Glas
Jul 28, 2017
05:57 AM
Jul 28, 2017
05:57 AM
Henk-Piet Glas
Rico wrote:
Hello together,
Henk-Piet Glas
03:59 AM
Aug 10, 2017
03:59 AM
Thank you very much this solved the problem
Aug 10, 2017
06:52 AM
Aug 10, 2017
06:52 AM
Brilliant. Happy to hear that.
Henk-Piet Glas
Apr 16, 2019
09:09 AM
Apr 16, 2019
09:09 AM
Hello Henk-Piet,
I am using app-kit tc397xa, when connecting the board to windows 10, there is only one COM port "infineon DAS JDS COM", there is no "DAS JDS DEBUG" or "virtual COM".
However, from the hightec's serial example, I am able to receive and send data through this "serial". Do you know how I can reload the drivers and operate more safely?
