User20083
25 replies posted 10 replies posted 5 replies posted
Calling
IfxSmu_unlock(&MODULE_SMU)
IfxSmu_lock(&MODULE_SMU)
causes the SMU to generate an SMU reset request.
Permanent lock is off (PERLCK reads 0)
SMU_CLC reads 0 (module is enabled)
SMU_ADn (n = 1 to 6) all read 0 before and after the lock/unlock functions are called (no known cause of SMU alarm)
SMU_AFCNT reads 0x00000020 (peculiar and not possible as bit 6 is reserved and should read 0/write 0 according to manual)
Why are the resets occurring?
I used the code same as in issue : https://www.infineonforums.com/threads/11779-SMU-software-alarm-trigger-using-SMU-CMD-%28Commands%29...
User20083
Kind reminder.
I really can't figure this one out. Please help.
NeMa_4793301
Level 6
Level 6
Hmm... I ran your code and couldn't duplicate the reset.
User20083
thanks, can you send me you version of the linker file? I think my one may not have a right configurations?
NeMa_4793301
Level 6
Level 6
I wouldn't expect linker file trouble to lead to a reset, but here you go:
BIFACES BaseFramework_TC23A Lcf_Tasking_Tricore_Tc.lsl
* \file Lcf_Tasking_Tricore_Tc.lsl
* \brief Linker command file for Tasking compiler.
* \copyright Copyright (c) 2018 Infineon Technologies AG. All rights reserved.
* IMPORTANT NOTICE
* Infineon Technologies AG (Infineon) is supplying this file for use
* exclusively with Infineon's microcontroller products. This file can be freely
* distributed within development tools that are supporting such microcontroller
* products.
* THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED
* OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
* INFINEON SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL,
* OR CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
#define LCF_CSA0_SIZE 8k
#define LCF_USTACK0_SIZE 2k
#define LCF_ISTACK0_SIZE 1k
#define LCF_HEAP_SIZE 2k
#define LCF_CPU0 0
#define LCF_DEFAULT_HOST LCF_CPU0
#define LCF_DSPR0_START 0x70000000
#define LCF_DSPR0_SIZE 184k
#define LCF_CSA0_OFFSET (LCF_DSPR0_SIZE - 1k - LCF_CSA0_SIZE)
#define LCF_ISTACK0_OFFSET (LCF_CSA0_OFFSET - 256 - LCF_ISTACK0_SIZE)
#define LCF_USTACK0_OFFSET (LCF_ISTACK0_OFFSET - 256 - LCF_USTACK0_SIZE)
#define LCF_HEAP0_OFFSET (LCF_USTACK0_OFFSET - LCF_HEAP_SIZE)
#define LCF_INTVEC0_START 0x801F4000
#define LCF_TRAPVEC0_START 0x80000100
#define INTTAB0 (LCF_INTVEC0_START)
#define TRAPTAB0 (LCF_TRAPVEC0_START)
#define RESET 0x80000020
#include "tc1v1_6_x.lsl"
// Specify a multi-core processor environment (mpe)
processor mpe
derivative = tc23A;
derivative tc23A
core tc0
architecture = TC1V1.6.X;
space_id_offset = 100; // add 100 to all space IDs in the architecture definition
copytable_space = vtc:linear; // use the copy table in the virtual core for 'bss' and initialized data sections
core vtc
import tc0; // add all address spaces of core tc0 to core vtc for linking and locating
bus sri
mau = 8;
width = 32;
// map shared addresses one-to-one to real cores and virtual cores
map (dest=bus:tc0:fpi_bus, src_offset=0, dest_offset=0, size=0xc0000000);
map (dest=bus:vtc:fpi_bus, src_offset=0, dest_offset=0, size=0xc0000000);
memory dsram0 // Data Scratch Pad Ram
mau = 8;
size = 184k;
type = ram;
map (dest=bus:tc0:fpi_bus, dest_offset=0xd0000000, size=184k, priority=8);
map (dest=bus:sri, dest_offset=0x70000000, size=184k);
memory psram0 // Program Scratch Pad Ram
mau = 8;
size = 24k;
type = ram;
map (dest=bus:tc0:fpi_bus, dest_offset=0xc0000000, size=24k, priority=8);
map (dest=bus:sri, dest_offset=0x70100000, size=24k);
memory pfls0
mau = 8;
size = 2M;
type = rom;
map cached (dest=bus:sri, dest_offset=0x80000000, size=2M);
map not_cached (dest=bus:sri, dest_offset=0xa0000000, reserved, size=2M);
memory dfls0
mau = 8;
size = 1M;
type = reserved nvram;
map (dest=bus:sri, dest_offset=0xaf000000, size=1M );
memory lmuram
mau = 8;
size = 32k;
type = ram;
priority = 2;
map cached (dest=bus:sri, dest_offset=0x90000000, size=32k);
map not_cached (dest=bus:sri, dest_offset=0xb0000000, reserved, size=32k);
memory edmem
mau = 8;
size = 512k;
type = ram;
map (dest=bus:sri, dest_offset=0x9f000000, size=512);
map (dest=bus:sri, dest_offset=0xbf000000, reserved, size=512k);
#if (__VERSION__ >= 6003)
section_setup :vtc:linear
heap "heap" (min_size = (1k), fixed, align = 8);
#endif
start_address
symbol = "_START"
stack "ustack_tc0" (min_size = 1k, fixed, align = 8);
stack "istack_tc0" (min_size = 1k, fixed, align = 8);
/*Section setup for the copy table*/
copytable
align = 4,
dest = linear,
table
symbol = "_lc_ub_table_tc0";
space = :tc0:linear, :tc0:abs24, :tc0:abs18, :tc0:csa;
/*Near data sections*/
section_layout :vtc:abs18
group (ordered, contiguous, align = 4, attributes=rw, run_addr = mem:dsram0)
select "(.zdata.zdata_cpu0|.zdata.zdata_cpu0*)";
select "(.zbss.zbss_cpu0|.zbss.zbss_cpu0*)";
# if LCF_DEFAULT_HOST == LCF_CPU0
# endif
select "(.zdata|.zdata*)";
select "(.zbss|.zbss*)";
section_layout :vtc:linear
/*Small data sections, No option given for CPU specific user sections to make generated code portable across Cpus*/
group a0 (ordered, contiguous, align = 4, attributes=rw, run_addr = mem:dsram0)
# endif
select "(.sdata |.sdata*)";
select "(.sbss |.sbss*)";
"_SMALL_DATA_" := sizeof(group:a0) > 0 ? addressof(group:a0) + 32k : addressof(group:a0) & 0xF0000000 + 32k;
/*Far data sections*/
group (ordered, contiguous, align = 4, run_addr = mem:dsram0)
select "(.data.data_cpu0|.data.data_cpu0*)";
select "(.bss.bss_cpu0|.bss.bss_cpu0*)";
# endif
select "(.data|.data*)";
select "(.bss|.bss*)";
/*Heap sections*/
group (ordered, align = 4, run_addr = mem:dsram0[LCF_HEAP0_OFFSET])
# endif
heap "heap" (size = LCF_HEAP_SIZE);
group (ordered, align = 8, run_addr = mem:dsram0[LCF_USTACK0_OFFSET])
stack "ustack_tc0" (size = LCF_USTACK0_SIZE);
"__USTACK0":= "_lc_ue_ustack_tc0";
"__USTACK0_END":= "_lc_ub_ustack_tc0";
group (ordered, align = 8, run_addr = mem:dsram0[LCF_ISTACK0_OFFSET])
stack "istack_tc0" (size = LCF_ISTACK0_SIZE);
"__ISTACK0":= "_lc_ue_istack_tc0";
"__ISTACK0_END":= "_lc_ub_istack_tc0";
group (ordered, align = 64, attributes=rw, run_addr=mem:dsram0[LCF_CSA0_OFFSET])
reserved "csa_tc0" (size = LCF_CSA0_SIZE);
"__CSA0":= "_lc_ub_csa_tc0";
"__CSA0_END":= "_lc_ue_csa_tc0";
"_lc_u_int_tab" = (LCF_INTVEC0_START);
"__INTTAB_CPU0" = (LCF_INTVEC0_START);
// interrupt vector tables for tc0, tc1, tc2
group int_tab_tc0 (ordered)
# include "inttab0.lsl"
group trapvec_tc0 (ordered, run_addr=LCF_TRAPVEC0_START)
select "(.text.traptab_cpu0*)";
group code_psram0 (ordered, attributes=rwx, copy, run_addr=mem:psram0)
select "(.text.psram_cpu0*)";
select "(.text.cpu0_psram*)";
group (ordered, run_addr=mem:pfls0)
select ".zrodata*";
group bmh_0 (ordered, run_addr=0x80000000)
select "*.bmhd_0";
group bmh_1 (ordered, run_addr=0x80020000)
select "*.bmhd_1";
group reset (ordered, run_addr=0x80000020)
select "*.start";
group interface_const (ordered, run_addr=0x80000040)
select "*.interface_const";
"__IF_CONST" := addressof(group:ainterface_const);
group a1 (ordered, run_addr=mem:pfls0)
select ".srodata*";
select ".ldata*";
"_LITERAL_DATA_" := sizeof(group:a1) > 0 ? addressof(group:a1) + 32k : addressof(group:a1) & 0xF0000000 + 32k;
"_A1_MEM" = "_LITERAL_DATA_";
select ".rodata*";
select ".text*";
group a8 (ordered, run_addr=mem:pfls0)
select "(.rodata_a8|.rodata_a8*)";
"_A8_DATA_" := sizeof(group:a8) > 0 ? addressof(group:a8) + 32k : addressof(group:a8) & 0xF0000000 + 32k;
"_A8_MEM" := "_A8_DATA_";
group (ordered, run_addr=mem:lmuram)
select "(.zdata_lmu|.zdata_lmu*)";
select "(.zbss_lmu|.zbss_lmu*)";
group a9 (ordered, run_addr=mem:lmuram)
select "(.sdata_lmu|.sdata_lmu*)";
select "(.sbss_lmu|.sbss_lmu*)";
"_A9_DATA_" := sizeof(group:a9) > 0 ? addressof(group:a9) + 32k : addressof(group:a9) & 0xF0000000 + 32k;
"_A9_MEM" = "_A9_DATA_";
select "(.data_lmu|.data_lmu*)";
select "(.bss_lmu|.bss_lmu*)";
select "(.lmu_data|.lmu_data*)";
select "(.lmu_bss|.lmu_bss*)";
select "(.data_a9|.data_a9*)";
select "(.bss_a9|.bss_a9*)";
"__TRAPTAB_CPU0" := TRAPTAB0;
User20083
You're right.
So what cause a reset when I am calling IfxSmu_lock or IfxSmu_unlock?
User20083
4623.attach
these are the registers after reset. this code was run soon after main
User20083
Any update?
Kind reminder
example project:
