Any RAM that is ECC protected must be initialized before it is read, to set the ECC bits.
If PROCOND.RAMIN is set to NO_INIT, is it possible to disable ECC protection on certain range of RAM, and read these uninitialized RAM locations as entropy source for PRNG ? Is there any application note / sample application on this topic ?
- NO_INIT RAM
- prng
- tc3xx
e.g.:
The DSPR memory of the TC1.6.2P is protected from memory integrity errors on a per half-word basis. ECC
protection of the DSPR is enabled via the SSH ECCS register.
Please see register MCi_ECCS (i=0-95) description in the MTU chapter. Disable here the ECC for the needed memory. The information which number is used for which memory you can find in the corresponding appendix manual.
No, this is not possible. You can switch off the ECC only for complete RAM.
Thank you for your response MoD. How to disable ECC over complete RAM?
e.g.:
