Apr 27, 2020
11:20 AM
Apr 27, 2020
11:20 AM
HI
I have a Hitex Tantino II debugger which I do not have a problem with, I also have a Lauterbach LA-3500 and a LA-7756 OCDS-Tricore I would like to try and use it again I managed to load elf files few years ago it stopped working I think through grounds being different.
I sent it back and Lauterbach who could not find a problem I thought I would get it out of the cupboard and try again.
I have a start up script adapted from a Easy kit TC1767 but for a TC1782 I just get command locked or
I have tried the following steps
Power LA-3500 with JTAG LA-7756 connected
Power up target
SYStem.CPU TC1782
SYstem.Up get ^ command locked
If I open up Tricore CPU window get
target reset
Tantino II works fine and once I got the Lauterback working although probably with a TC1767 in although mainly just uploading elf files
Carl
Power up target
SYStem.CPU TC1782
target reset
Carl
12:17 PM
Apr 27, 2020
12:17 PM
The LA-7756 supports both JTAG and DAP. How are you connecting via the Tantino?
This is what I use (w/JTAG):
SYStem.CPU TC1782
SYStem.CONFIG CORE 1. 1.
SYStem.Option.RESetBehavior Halt
SYStem.Option ResetMode PORST
SYStem.Config.DEBUGPORTTYPE JTAG
SETUP.TabSize 2
SYStem.Up
If you are using DAP then substitute this line
SYStem.Config.DEBUGPORTTYPE DAP
SYStem.CPU TC1782
SETUP.TabSize 2
SYStem.Up
Apr 27, 2020
12:37 PM
Apr 27, 2020
12:37 PM
Thanks for the quick responce really appreciated
I just checked I got the Lauterbach back in July 2018 this is first time I tried it
I am using JTAG with the Tantino thanks for the suggestions commands but I still get ^ command locked
I notice if I try SYStem.Config.DEBUGPORTTYPE DAP I also get ^ command locked
I also read some time ago it might be a power issue I am interchanging the 16pin JTAG Tantino is fine Lauterbach is not
I started of with target on bench on it's own the problem started when I put it in the machine has a ground on at a different potential I am now back to target on the bench.
One difference is the Tantino does not require a power supply just USB
I did add just in case.
IF DAP.Available()
; Bi-Directional Debug Cable detected
SYStem.CONFIG.DEBUGPORTTYPE DAP2 ; instead of JTAG
ELSE
; Uni-Directional Debug Cable
SYStem.CONFIG.DEBUGPORTTYPE JTAG
IF DAP.Available()
ELSE
