Hello everyone! I am using the HighTec compiler to try to compile the code AP32540 PMSM FOC AURIX TC3xx obtained from the official website of Infineon, and currently encounter the following error reporting problem:
Sales name:KIT_A2G_TC387_MOTORCTR
Open the location of the error report as follows:
Program "$(TRICORE_TOOLS)\bin\tricore-gcc" not found in PATH
At present, I have tried to add the path of tricore-gcc.exe in many places, but the problem has not been effectively solved.
Hope to get your answers!
AURIX
BIFACES is a traditional framework to build some example projects which has a long history, supporting 4 types of compiler. So after installed BIFACES, you should configure the compiler path to build. For the compiler, it has its own IDE, but it's not verified by practice. So, generally, we have not put effort on its own IDE unless you would like to migrate the project which needs time.
Could you please check if HIGHTEC is supported by this project? You can check the default project file inside.
how can i download BIFACES?
I have completed myicp registration, but I still can't find the download address of Biface, what's the matter?
Please send email as the webpage required properly and waiting for approve. It takes time to grant the right.
Is Biface a specific software? Why can't I find a specific download entry?
Yes, it should be downloaded from myICP.
After install BIFACES, you can config your Hightec compiler path as attached screenshot showed.
If Bifaces is not installed, is it impossible to run the project code I mentioned? It has been a day but I still have not received a reply to the promoted user application. Is there a way to run and program the code without installing Bifaces?
I imported the files downloaded from Infineon's official website into hightec, why can't I set active project?
This project is compiled with hightec, why can't I compile the project after importing it on my computer? Does this have something to do with not installing Biface?
I have sent an email like the picture below, how long will it take to get a reply?
