Using Hightec with error Program "$(TRICORE_TOOLS)\bin\tricore-gcc" not found in PATH
yhl
5 sign-ins 5 replies posted First reply posted
Hello everyone! I am using the HighTec compiler to try to compile the code AP32540 PMSM FOC AURIX TC3xx obtained from the official website of Infineon, and currently encounter the following error reporting problem:
Sales name:KIT_A2G_TC387_MOTORCTR
Open the location of the error report as follows:
At present, I have tried to add the path of tricore-gcc.exe in many places, but the problem has not been effectively solved.
Hope to get your answers!
Di_W
BIFACES is a traditional framework to build some example projects which has a long history, supporting 4 types of compiler.  So after installed BIFACES, you should configure the compiler path to build. For the compiler, it has its own IDE, but it's not verified by practice. So, generally, we have not put effort on its own IDE unless you would like to migrate the project which needs time.
Di_W
Could you please check if HIGHTEC is supported by this project? You can check the default project file inside.
yhl
how can i download BIFACES?
Di_W
Please register myicp.
yhl
I have completed myicp registration, but I still can't find the download address of Biface, what's the matter?
Di_W
Please send email as the webpage required properly and waiting for approve. It takes time to grant the right.
yhl
Is Biface a specific software? Why can't I find a specific download entry?
Di_W
Yes, it should be downloaded from myICP.
Di_W
2023-02-16 15_16_54-eclipse-workspace - AP32540_PMSM_FOC_AURIX_TC3xx_1_ToolEnv_0_Build_1_Config_Conf.png2023-02-16 15_17_25-eclipse-workspace - AP32540_PMSM_FOC_AURIX_TC3xx_1_ToolEnv_0_Build_1_Config_Conf.png
After install BIFACES, you can config your Hightec compiler path as attached screenshot showed.
yhl
If Bifaces is not installed, is it impossible to run the project code I mentioned? It has been a day but I still have not received a reply to the promoted user application. Is there a way to run and program the code without installing Bifaces?
yhl
I imported the files downloaded from Infineon's official website into hightec, why can't I set active project?
This project is compiled with hightec, why can't I compile the project after importing it on my computer? Does this have something to do with not installing Biface?
yhl
I have sent an email like the picture below, how long will it take to get a reply?
Di_W
