I am using a TC222 evalboard with a LA-2707 Tricore Automotive PRO dongle plugged on DAP used for debugging. Debug is working by using Trace 32 tool.
To be able to change the UCBs, i need to connect to the evalboard by using MemTool and DAS. But, as you can see in the screenshot below, Lauterbach connector is connected to the PC, but DAS does not see it.
Is DAS compatible with Lauterbach probe, or only with miniwriggler? If it is compatible, how to setup DAS?
Thank you.
Best regards.
Hi @Fabien . DAS only works with a USB connection through the FTDI chip on the TriBoard, or with a miniWiggler. The Lauterbach USB device is not supported by DAS.
You can also change UCBs via scripts in Trace32.
OK, thank you.
