Using AURIX TC375 compiler outside of IDE
ja1
First reply posted 5 questions asked 5 sign-ins
I am trying to integrate support for the AURIX TC375 into my current custom build system which uses makefiles to compile my project code. I have been unable to use the TASKING compiler outside of the IDE. Are there any suggestions as to how I should approach this problem, and / or which compilers I should use?
Thank you!
Jeremy_Z
1000 replies posted 250 sign-ins 100 likes received
Hi @ja1
1) Are there any suggestions as to how I should approach this problem, and/or which compilers I should use?
-- Firstly, it's impossible to use the TASKING compiler without the AURIX™ Development Studio, next, you can try other IDEs to develop the AURIX series MCU.
BR,
Jeremy
Jeremy_Z
Hi @ja1
BR,
Jeremy
