AURIX™ Forum Discussions
User18151
First solution authored
Hi AURIX Community,
Is there a recommendation as to how to fill unused flash locations so that a trap is generated if code is executed from those areas?
Happy to hear from you!
Christine
#8042000 12174
User18237
Hi Christine,
Unused flash locations can be filled with 0x36. This will cause an illegal opcode trap to be generated. It is valid for all AURIX TC2xx and TC3xx.
Mr.AURIX™
