AURIX™ Forum Discussions
User18757
5 questions asked First like received First reply posted
I'm looking for a way to view and extract the content of an uninitialized RAM section of an 3xx cpu.
Is the only way to rewrite the UCB with new RAMINSEL values?
And what would be the proper way to do this and what are the pittfalls?
Marcus
cwunder
25 likes received 25 solutions authored 100 sign-ins
I am not sure of your intent, almost all of the SRAM on these devices has ECC so reading uninitialized SRAM is not reliable as the ECC bits associated to that SRAM block are also uninitialized. You MUST have a write operation to set the ECC on the SRAM before reading it.
User18757
My intent is to get the uninitialized data to conduct some statistical analysis on it. My idea was also to disable the memory integrity control for e.g. the LMU mem to read the memory without ECC error.
User18757
Problem solved.
abcd1234
First like received First reply posted Welcome!
Could you please mention how you could disable ECC on RAM? We would like to read it for random number generation.
User22447
First like given 5 replies posted 5 sign-ins
Is it necessary to initialize the RAM memory during startup? What if I skip initialization and what is benefit it initialized?
RAMINSEL[21:16] does it possible to initialize all the core RAM initialization simulteneously?
Sagar
