AURIX™ Forum Discussions
hello All,
I am very new to Tri-core.
I need better understanding of the Tri-core , from Application perspective
1. How the applications interacts between the cores.
2. Does the single core is sufficient for most of the tasks if yes how to determine the maximum number of applications that a single core can work efficiently, any reference document for the same.
Kindly help me on the same...share the link if you have.
Naveen Kumar S
Hi Naveen,
Do you got any idea on how to work on different cores of tricore controller..ie,by defualt it is working on core 0 .but i want my application to work on core1. Please help me if anyone knows the same.
Thanks in advance.
Would you please share the answer if you have.
User9888
pram,s wrote:
Hi Naveen,
Thanks in advance.
Hi Pram,
Which compiler are you using?
Henk-Piet Glas
Technical Product Specialist
