May 06, 2019
06:17 AM
May 06, 2019
06:17 AM
Hi ,
I am using tc233 triboard . I try to flash (.elf) using usb to jtag cable through Hightec development platform , getting following error
Message from component 'Tc2CoreTargIntf' :
Can't connect target !
Can't connect JTAG target.
I am using FT232HL for this usb to jtag conversion . In one of the evaluation board for aurix TC-297 , they were using same IC FT2232H , its working well for Hightec platform.
Please suggest some solution to resolve this issue to flash using usb.
May 08, 2019
05:35 AM
May 08, 2019
05:35 AM
With the FT232HL this will not work. You need such a device as interface: https://www.ehitex.de/en/accessories/2505/dap-miniwiggler-v3 or https://www.ehitex.de/en/accessories/2276/dap-miniwiggler?c=120
May 08, 2019
11:09 PM
May 08, 2019
11:09 PM
Thank you.
Jul 15, 2019
09:48 PM
Jul 15, 2019
09:48 PM
Hi Sir,
Our use case is USB programmable Controller module. So is it possible to use FT232H or FT2232H in our Controller module to program our infenion controller using USB?
Jul 16, 2019
02:22 AM
Jul 16, 2019
02:22 AM
For programming you need an interface like this ones, only a single device is not possible:
or
or
