UART ASCLIN RXFIFO is 16 byte can't handle more than 16 byte receive correctly Aurix TC397
aMantawy
First reply posted First question asked 10 sign-ins
I'm using AURIX TC397 ASCLIN UART  and it receive up to 16 byte perfectly with baud rate 921600 , if the data exceed than 16 byte I face a data shifting a circular shift ,  I need a help to design a piece of SW that Handle the receiving
Aiswarya_A
25 likes received 250 sign-ins 50 solutions authored
Could you please share the code snippet or the  .c file to understand the issue better?
You could also refer to this example.
Kind Regards,
Aiswarya.
