At the end of FW execution after Cold Power-on Reset, during the FW evaluation by Application SW:
In case all registers and SMU alarms report the expected values, the Application SW shall: - clear the content of the registers mentioned in the table (except STMEM3..6 and LCLCON0.1), - clear the SMU alarms SMU_AGO..11, clear the corresponding reset status bits in RSTSTAT register. proceed further.
1-should we know the type of reset before fw check, and if yes, how could we know this type?
2-what is the number of table that should be cleared in appendix A and shall We clear all the registers except that is mentioned or specific registers in this table?
This cannot be discussed under public forum since this topic is covered under NDA.
Aiswarya.
