AURIX™ Forum Discussions
User19424
Hello
I am having trouble reading the A11 Register.
I tried:
__mfcr(CPU_A11)
(&CPU0_A11)->B.ADDR
*((unsigned int *)&CPU0_A11)
//Also Tried with inline assembly
int *res;
__asm__ volatile ("mov.aa %0, %%a11": "=a" (res) : :"a11");
return res;
But none seem to work. Can someone please help me?
Thank you very much.
NeMa_4793301
Level 6
Level 6
This didn't work?
int res;
res = __mfcr( CPU_A11 );
What value did you get? What were you expecting?
User19424
UC_wrangler wrote:
This didn't work?
int res;
I get 0
I was expecting to get the address located in a11, but the mnemonic places 0 into d15, instead of the expected address.
I noticed from reading the documentation that __mfcr is only intended for CSFR Registers. Could this be why it doesn't work for General Purpose ones?
NeMa_4793301
Level 6
Level 6
I think you're right about __mfcr and general registers - coffee hasn't kicked in yet :).
How about this:
register int res asm("d0");
__asm__ ("mov.d %d0, %a11" );
User19424
How about this:
I may also be making a silly mistake, but doing this gives me
syntax error - token ";" inserted before "asm"
Is there something I have to import for this to work properly?
Thought maybe a "=" was missing but that just gives me linker errors
NeMa_4793301
Level 6
Level 6
Sorry - which compiler are you using here? The one I posted was gcc (Hightec) syntax.
User19424
Tasking 🙂
NeMa_4793301
Level 6
Level 6
And here I went to all the work of installing GCC just to answer 😛
In Tasking, it's:
volatile int res;
__asm( "mov.d %0,a11" : "=d"(res) );
User19424
In Tasking, it's:
volatile int res;
This works. Thank you! 😄
