AURIX™ Forum Discussions
User17142
I am using HighTec compiler to develop applications on top of TC297-B mircrocontroller. The problem I am facing is I am unable to activate core 1 or 2 from core 0. I used the following line to set core 1 or 2 CPUx_DBGSR.B.HALT=2; but corers are not activated. So could you please assist in what I am missing. Also, how to place conditions in startup code to activate the cores.
If any inputs on integration of FreeRTOS with TC297 will be helpful.
Many Thanks,
Kumaresh
User17079
Hi Kumaresh,
If you are using IFX MCAL, I would recommend you to refer to the startup.c file.
This has the startup code for both single and multicore configurations.
Sivakumar M.
