AURIX™ Forum Discussions
Daniel27
5 questions asked 10 sign-ins 5 replies posted
Hello world, I'm using  Aurix TC377 microcontroller and I have a question. Can I manage the ADC acquisition after a trigger signal for example a PWM signal from ATOM because I don't want to make the acquisition continuously but I want to be synchronous after a certain event( PWM signal).
Thank you in advice!!
Yuva
100 solutions authored 25 likes received 100 sign-ins
I guess you are referring to EVADC, there are hardware triggesr to request the ADC conversion. You can refer to section 32.5.2 in the hardware user manual part 2 for details.
Yuva
Hello Yuva,
I am facing an issue after configured EVADC Queue, which is triggering at TOM PWM signal.
Triggering period of EVADC queue is 102us and i am getting data in DMA but some times VF bit is 0.
why this VF bit is coming 0 ?
Could help me to find the solution ?
Yuva
I see you already have a similar discussion in https://community.infineon.com/t5/AURIX/EVADC-Valid-flag-randomly-shows-0-while-linked-with-DMA/td-p.... I request you to continue the discussion there.
