- Email to a Friend
Hi all
I'm tring to set up the ADC start of conversion from the period match event of the CCU60 T13 timer.
I've set XTSEL to 0 (to select SR3 of the EVADC) but then I've notice that SR3 is only set if the interrupt enable (in this case CCU60_IEN.ENT13PM) .
This means I can't have SR3 without having an additional interrupt on the period match event? There is a way to avoid?
- Email to a Friend
Can you refer to the Aurix Development Studio(ADS) example for https://www.infineon.com/dgdl/Infineon-AURIX_CCU6_ADC_1_KIT_TC397_TFT-Training-v01_00-EN.pdf?fileId=...
Best Regards.
- Email to a Friend
Best Regards.
- Email to a Friend
Solved ,Thanks! I was tring to use only the init function present into the Illd (IfxCcu6_Timer_initModule) and with only this function is not possible since the setting of the interrupt source signal and routing is possible only if the interrupt is enabled!
