AURIX™ Forum Discussions
User15969
Hello there.
I have been trying to read TC1782 on-board and trying to figure out which pins could be GPT S1 and GPT S2 on MCU?
Any help from you guys will be highly appreciated.
It’s Infineon Tricore “K-TC1782N-320 F180HL”
I have got it’s datasheet and pinout description but unable to identify proper GPT pins from them.
Kindly guide me on this...
Thank you.
cwunder
I am not sure what pins you are referring too? What port pins are "GPT S1" and "GPT S2"?
User15969
Can you help me with BSL to read this MCU on-board?
cwunder
Which BSL mode are you using on the TC1782?
The BSL mode is dependent on pins P0[7:0].
After any device start the currently valid start-up configuration is indicated in bitfield HWCFG of register SCU_STSTAT
After any system reset values upon the rising reset-edge (SCU_STSTAT.LUDIS=0) configuration pins P0[7:0] are latched
The two most common are listed below (see the manual for more information)
HWCFG[7:0]
010xxxx0B Bootstrap Loader Mode, Generic Bootloader at CAN pins
10101xx0B Bootstrap Loader Mode, ASC Bootloader
Then you need to follow the defined protocol for the respective mode you have chosen.
User15969
HWCFG[7:0]
Thank you for your understandings and reply.
I request you to please visit this post made by me in reference to my query.
I need BSL and pinouts for this specific module.
Kindly help me.
https://www.infineonforums.com/threads/6233-How-to-Read-Write-FLASH-and-EEPROM-of-%28Infineon-Tricor...
Waiting for your reply.
User17799
First like received
Refer to application note #32136, good luck finding the code that it references in chapter 7.
