che
Distributor
First like given 5 replies posted 10 sign-ins
I have a question for i51 interrupt.
Environment: build triboard_TC39X example code with BIFACES and use keil toolchain to compile i51.
1. In i51_main.c: It's enabled RTC and NMI interrupt, but I can't find how to install interrupt and how to define the interrupt number with keil compile as below pics.
I know the interrupt vector value in SCR datasheet and install the interrupt by assembly with Tasking toolchain. But where can i find the reference or info for keil i51 interrupt define?
#AURIX #Tricore #SCR #i51 #BIFACES
che
Distributor
Hi dw,
Thank for reply.
Right, I can find SCR interrupt vector on SCR session. But actually I don't know how to map the keil 8051 interrupt vector.
Finded the keil ap_note 103 and explained the interrupt number and vector at this link:https://www.keil.com/appnotes/files/apnt_103.pdf
Di_W
You can find information on SCR interrupts on page 3279, in section 49.9.1.1, Interrupt Source and Vector, in the user manual for TC39x at this link: https://www.infineon.com/dgdl/Infineon-AURIX_TC3xx_Part2-UserManual-v02_00-EN.pdf?fileId=5546d462712...
che
Distributor
Hi dw,
Thank for reply.
