AURIX™ Forum Discussions
User21707
First like received
Can two TC boards of different make i.e TC297 and TC375 be connected to the same PC and be switched through them when required to use ? Lauterbach is used to connect the hardware to the PC.
Simultaneously both won't be in use. Only 1 board at a given time will be in use.
[Curious: Can both boards be in use simultaneously? ]
Thanks!
Jeremy_Zhou
25 solutions authored 10 solutions authored 10 likes given
Hi @User21707 ,
Regarding your question, I'd like to suggest you contact Lauterbach directly for some advice.
BR,
Jeremy
