I cannot create tresos project appropriately like below capture.
When I check MCAL_UM_DemoApp, there is EB tresos TNG GUI.
Is there special tresos version different from tresos 26.2?
Tresos: 26.2
MCAL: MC-ISAR_AS440_TC49A_BASIC_4A.1.10.0-alpha1
- TC499 Tresos
Dear customer,
MCAL topic is not discussed here.
Please check have you download Tresos TNG?
Plugin files
Folder name Description
schema Contains the arxml files for the module located in
\MCAL\01_PluginsTresos\eclipse\Plugins\<Mod>_Aurix3G
Generate Contains the template for the generated files for the module \MCAL\01_PluginsTresos\eclipse\Plugins\<Mod>_Aurix3G
plugin.xml Contains the plug-in information, located in
Creating an EB tresos TNG configuration project:
Prerequisites:
Ensure tresos TNG is installed and module plugins copied to the tresos TNG installed plugins directory
E.g: C:\tresosTNG\<version>\tresosTNG\plugins.
Note: JAVA 8 JDK or JRE version should be installed in user's machine for TNG usage.
dw
