AURIX™ Forum Discussions
User17614
I get a trap when I try to write registers of a peripheral module? What could be the reason?
#8042000 11483
User16898
Level 4
Level 4
What register you want to write?
module register can be protected by ENDINIT functions you need to disable them via WDT module:
uint16 cpu_wdt_password = IfxScuWdt_getCpuWatchdogPassword();
IfxScuWdt_clearCpuEndinit(cpu_wdt_password);
User17615
First like received
Module clock not enabled (Check _CLC register. (Should be written with 0 before the access. Or is there is a protection on the register that needs removal prior to a write access: Safety Endinit or CPU Endinit.
